crappy crab style distributor cap
It’s also why the 496’s go thru plug wires (and sometimes coils) too quick.
OE spec .060” plug gaps. Don't do it.
Friends don’t let friends run stupid large plug gaps
as I said earlier I have been reducing the gaps just dont remember on my truck if I did that last time I put plugs in it. that was more than a year ago so my memory of that has been deleted to make room for more useless knowledge. havent pulled the plugs yet to see what I did.
changed it out and it immediately went back to normal idle (was idling several hundred high) and smoothed out so big improvement. cap did not look bad but rotor looked like it had been hot, not sure why but it runs like normal now so hopefully the brass cap will hold up better.
Now it seems that a lot of people talk about decreasing the spark plug gap. But what about the air gap between the distributor electrodes and the far edge of the rotor? I don't know what the air gap is of GM and other distributor caps/rotors are. I do know what the air gap is of the vortec (crab) is. It's 0.160"! That's a huge leap for an electrical arc. That arc jump probably has more to do with the Caps demise than a spark plug gap of 0.060.
