Mystery BBC please help >
Old 05-12-2025 | 08:06 PM
Originally Posted by Capt.Jack
Here is a short video of the idle
No link....
Roller link-bar lifters in the Gen V...gtg.
TThse are my stock 088 heads with 25 hrs of use. They just hogged in, then put a seat in for the intake valve. No venrturi under the valve. This really hurts flow. Aluminum, you could weld it up and shape it. Iron...all you can do is put 2.300 valves in and see if the throat is small enough at 90%.
But the 088 heads will flow with some cam and rpm. You should have inconel exh valves as well...if stock.
Let us know how it runs when you get it wet.
Tartilla is offline
Old 05-13-2025 | 05:46 AM
What is the issue with link bar lifters and the gen v block?
Capt.Jack is offline
Old 05-13-2025 | 06:03 AM
Need to hit 10 posts to be able to post url found out…
Old 05-13-2025 | 06:04 AM
video of the idle, let me know what you all think?
Old 05-13-2025 | 06:33 AM
https://youtube.com/shorts/cVviyM_rl...D-HiOijsyPdTgu
Sounds good to me. Here's what this cam spec sounds like Bullet 244/250 112 .664/.663:
SecondWind is offline
Old 05-13-2025 | 07:09 AM
Sounds good, can definitely hear the Cam in yours! based upon what I can hear in mine at idle, it definitely does not sound like a stock cam. But not super aggressive either. Curious what the general consensus is about it?
Old 05-13-2025 | 11:08 AM
No issue..GTG = Good to Go. My back for using it.
Thr mentioned intent was that you obviously also have a non-stock cam if you have roller lifters from a Flat Tappet.
Tartilla is offline
Old 05-13-2025 | 11:10 AM
I gotcha, I read it as got to go lol. Where you able to view the video link I posted. I’d like to know your thoughts on if you can glean anything from the idle sound?
Old 05-13-2025 | 12:58 PM
SB
I can make regular cams sound pretty lopey at idle and I can make pretty big cams idle pretty smoothly. So I don’t get it. A cam in a bbc can be 0-10-50-100hp or so difference with nothing else changed.
SB is offline
Old 05-13-2025 | 02:41 PM
does it matter if it is 300 or 600 hp? it is going to do what it does so you are going to prop it to run where it is happy. if it only turns 4000 then prop it down, if it turns 6000 then prop it up. you will feel when it seems to run the best so stop worrying about hp numbers or speed and just let it do the best it can and enjoy it.
compedgemarine is offline
