Oil blowout from breather – 509 w/ 8-71 Blower >
Oil blowout from breather ? 509 w/ 8-71 Blower
Old 06-04-2025 | 12:39 PM
Originally Posted by Mbam
The hair and cell phone! Love it
hogie roll is offline
Old 06-04-2025 | 01:50 PM
Originally Posted by PROP STAR
Do a leakdown and compression test , hopefully Midwest Engine Tech in Mokena didn't build your motor and set ring gaps at .0040
This engine is built in Sweden by the first owner here.
JohanSweden is offline
Old 06-05-2025 | 11:19 AM
Originally Posted by JohanSweden
Thank you for your advice.
I spoke with a friend who has installed evac systems on several engines, including marine applications.
With this setup, negative pressure is created in the crankcase.
As shown in the attached picture, the hoses are routed to the exhaust and fitted with check valves.
Yes, I don’t think I’ll have space for a vacuum pump. But the evac system I mentioned earlier – could it work in a similar way?
yes,this the system i used. Eliminated oil misting issues.
William Diggens is offline
Old 06-08-2025 | 03:57 PM
do you know any good vacuum pump kit for my application? For blower engine.
Old 06-08-2025 | 03:58 PM
Originally Posted by ICDEDPPL
That`s over kill and unecessary, usually there`s no room with a sea pump anyway .
No reason to reinvent the wheel.
talked to a friend who knows guys building engines for street race and drag racing. He said it will only be good with a vacuum pump for my application. The evac for exhaust would be too small
Old 06-09-2025 | 09:51 AM
Thumbs up
Well, if your friend talked to a friend who knows guys building engines for cars, then I`d definitely take their advice over the guys who actually know boats.
Good luck!
ICDEDPPL is offline
Old 06-09-2025 | 10:56 AM
Good luck!
Just trying to fiend the best solution for my engine. Maybe it’s unnecessary and just need evac kit for exhaust. It’s that what you saying?
Old 06-09-2025 | 05:13 PM
I`m saying get a Catch can and move on with your life.
If that`s not good enought you have other problems.
Why overcomplicate things?
ICDEDPPL is offline
Old 06-10-2025 | 06:37 AM
The info I got is that even with just a catch tank, crankcase pressure remains — which is almost impossible to eliminate with a blower engine. A vacuum pump, however, solves the problem by effectively removing the pressure from the crankcase, that’s what I’ve been told.
But sure, if you say a catch tank alone is enough, who am I to argue.
Old 06-10-2025 | 07:06 AM
Mbam's Avatar
Offshoreonly Advertiser
Exactly
A little blowby is normal, too much for a catch can indicates a problem. In reality the breathers should handle it.
Mbam is offline
