Oil blowout from breather – 509 w/ 8-71 Blower >
Oil blowout from breather ? 509 w/ 8-71 Blower
Old 06-10-2025 | 07:09 AM
  #31
Originally Posted by Mbam
Exactly
A little blowby is normal, too much for a catch can indicates a problem. In reality the breathers should handle it.
I listen to what you guys say, and I think I’ll start by trying the catch can. But first, I’ll do a leak-down test.
JohanSweden is offline
Old 06-10-2025 | 08:25 AM
  #32
TeamSaris's Avatar
Driver-441
Racer
We use Teague valve covers, moroso breather tubes with double baffles and a plate welded into the cover. On a LONG hard run, a little smear out of the breathers. Im talking 5000+ for an hour. No catch can needed. 900hp+
Do a leak down.
TeamSaris is offline
Old 06-10-2025 | 08:39 AM
  #33
Do a leak down.
I have Keith Eickert valve covers.
At the rear of the valve covers, the tubes run up to the breathers/filters, as you can see in the #4 post. I don’t know if there is any baffles inside or just open tubes. Gonna check this.
Could the position of the breather tubes be a problem? Maybe they should be mounted at the front of the valve covers instead, where the oil fill caps are located.
Old 06-10-2025 | 09:59 AM
  #34
TeamSaris's Avatar
Driver-441
Racer
Moving them to the front will for sure help
