Exhaust gaskets
You just buy premium felpros or mr gasket ultraseal header gaskets. I coat them with antiseize, reused same set thru multiple rebuilds on my baja. As long as there not ran leaking, they last quite a while, I had stainless marine gen 3 manifolds, Smitty
the whole problem is I HATE anti-seize. seems if I walk with in 5 feet of it I have it all over my hands, shirt, tools, shop floor, bench, etc. I swear you could cover an entire house with a pint bottle of it. other than that it works great.
Mine would be used with CMI headers instead of manifolds if that makes a difference?
Thank you
Worse than silicone!!!
[QUOTE=xlint89;4932615]I would say yes. Although they might have a teflon (silver/gray color) coating on them?
Thank you[/QUOTE
it makes no difference, as long as the surface is clean and fkat, you put a very thin coat on, i put it on tbe stainless exhauat bolts too so they dint gall, especially in aluminum heads.
Thank you[/QUOTE
I use them all day on aluminum heads. But i am also doing it with the head on the bench in front of me. Makes it a little easier
