Getting analog guages to work >
Old 10-15-2025 | 08:04 AM
Default Getting analog guages to work
I installed a simrad uw on my donzi and would like to get the analog tachometer guages to work alongside.
i am having trouble getting it to function.
would anyone be able to help me set up to work correctly?
I have attached a picture for reference
thanks!
intimid8 is offline
Old 10-15-2025 | 08:54 AM
Veteran: Army
Tach should be a simple setup, 12V, ground, illumination, and a signal wire coming from the ignition system or PCM.
DrFeelgood is offline
Old 10-15-2025 | 09:19 AM
I do not know if that would work for tachs I have attached a drawing how I’ve wired everything to nmea
thanks!
intimid8 is offline
Old 10-15-2025 | 12:20 PM
Veteran: Army
If it's a Smartcraft gauge, with a multi-pin deutsch connector on the back, then disregard prior post.
Old 10-15-2025 | 02:14 PM
thanks!
Is that J Box mercrury? They make an adapter harness that plugs into the j box and has analog gauge output wires
Ryanw10 is offline
Old 10-17-2025 | 09:43 AM
it is a j box
I believe what you are referring to is the agi? Attached
intimid8 is offline
Old 11-17-2025 | 10:33 PM
Default J box
I have a like new tested converter box I would part with.
Fstboater1 is offline
Old 11-18-2025 | 04:06 AM
Learning
Triage is offline
Old 11-18-2025 | 04:12 AM
This is what I was thinking of, but you may need to run the agi box in addition.
https://www.greatlakesskipper.com/me...BoCHcUQAvD_BwE
Ryanw10 is offline
