Broken Exhaust Dam Flapper
#53
Guys,
Getting ready to reinstall these, using 4200. What do we use to clean up the overage? I don't think I want to use acetone or MEK like the tube suggests. It says to not use alcohols, as it will inhibit curing. Kinda wish I'd read that before I installed the bracket and bulkhead fittings for my steering conversion....
Thanks. Brad.
Thanks. Brad.
#54
Mine was put together with a regular rubber gasket that goes between the flange and the transom. They seal up great. Boat is 38yrs old and transom is as dry as the day it was built. I'd find the proper gasket before gluing everything together when you don't have to.
#55
Guys,
Getting ready to reinstall these, using 4200. What do we use to clean top the overage? I don't think I want to use acetone or MEK like the tube suggests. It says to not use alcohols, as it will inhibit curing. Kinda wish I'd read that before I installed the bracket and bulkhead fittings for my steering conversion....
Thanks. Brad.
Thanks. Brad.
i also use blue painters tape to ensure the 4200 only goes where i want it, once done you can remove the tape and GENTLY fair the seam if its standing to proud on the tape edge,
SLOW and steady
#59
Looks like I'm a little late on on this one, but these worked great for me 4" Slip-On Silent Seal Flap Assembly. Hopefully this helps out the next person that has to do this.
