Drive Stud Washer Question
Guys,
In the beginning stages of doing the hydraulic steering conversion in the PQ. While bolting on the drive steering bracket, I noticed this:
What is it and what does it do?
For the time being, I removed it, as it would jack the bracket up and nothing would line up properly. I could put a washer on other three studs, but thought I’d ask if I even need to worry about it.
Thanks. Brad.
Thanks. Brad.
Makes sense. Interesting, though, that the Mayfair kit instructions mention nothing about it, and the bracket is not machined to accommodate it. I guess I need to find three more washers of the same thickness to level them all out.
Thanks. Brad.
Or drill a hole in the Mayfair bracket in the correct location and use a longer screw. Probably make it oversize.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
I think I pictured the setup wrong. I was thinking it was a flat plate Oops.
Probably wouldn't hurt to drill the bell housing and use one of the screws and cables from the continuity kit to insure the ground.
https://www.mercruiserparts.com/bam/...l/37499833/282
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
Thanks. Brad
Sort of related
but I needed new stainless lock nuts for my outdrivrs
All the usual places wanted 6 to 10 dollars for one
So searched the specs and found a place called AFT
A box of 100 . Under 50 dollars
Washers were a tad less
My go-to is almost always McMaster-Carr.
7/16-20 Stainless Lock Nuts
Works out to about a buck each, including shipping.
Thanks. Brad.
PowerBoatr,
Thanks. Brad.
Thanks. Brad.
