Cam for Stock 575 SCI >
Old 01-16-2026 | 06:21 AM
Default Cam for Stock 575 SCI
Looking for suggestions for a hydraulic roller cam for a couple mostly stock 575 SCI. They already have the 3-1/2" blower pulley and we are adding the Whipple low profile chiller and doing some bowl blending and runner work on the heads. Any suggestions would be greatly appreciated.
BetaBob is offline
Old 01-16-2026 | 09:44 AM
You have the GM factory Rec Port 088 heads? 2.19/1.88?
These heads will perform, but the exaust port is less than stellar for NA...never mind a SC.
What are you looking at for HP goal? What RPM?
Keeping the TBI?
Using the opportunity to bump up the RPM a bit to 5500 (from the Merc peak spec of 4800-5200) would get you more HP and take strain off the drives a bit. Maybe with more HP form the upgrades...your current props may workout going higher rpm.
Tartilla is offline
Old 01-16-2026 | 11:46 AM
I have been looking for the cam card that I put in my 575, but have been unable to locate it. Eddie Young spec'd it and it was ground by Bullet cams. I would give him a call.
snapmorgan is offline
Old 01-16-2026 | 01:25 PM
I have talked to Eddie .Great guy. Knows his stuff. However his package includes his new injection and fuel system. Didn't seem like he had anything for stock setup.
the engines currently have the 3-1/2" pulley and the red line is set at 5400 RPM. Basically looking for a hydraulic roller to replace that flat tappet and gain a little more power.
BetaBob is offline
Old 01-16-2026 | 02:57 PM
bn
Eddie's cam, injection and fuel system were a great upgrade for my motors! Night and day difference starting and idling and gained more power too.
bn is offline
Old 01-16-2026 | 03:23 PM
I'd put a 525EFI cam in it
Teague Custom Marine | BBC Gen V-VI Billet Camshaft - Stage 2
Griff is offline
Old 01-16-2026 | 05:08 PM
Mine were Isky
Going off the sheet
Grind GR-762-IN
GR-764-EX
int dur 282
ex dur. 290
.050. Dur. In. 236. Ex. 244
cam lift. .632 on both
I went with dart iron eagle heads when I upgraded
You’ll want to get rid of that horrible merc ECM tune also
JaayTeee is offline
Old 01-17-2026 | 12:37 PM
A lot of good information. Appreciate the replies.
What started out as a 'freshen up", for a friend, has turned into a total rebuild. My experience is with drag racing on 4 wheels so this go fast boat stuff is a bit different. From my research the 525 EFI / Teague Stage 2 cam seem like the logical choice. I suspect that the TBI setup is not performing optimally even the with Arizona Speed tune. So it's likely we'll wind up with Eddie's injector setup or something similar. And then there's the blower.
BetaBob is offline
