Bow tie blocks >
Bow tie blocks
Bow tie blocks
Old 02-20-2026 | 08:17 PM
tripps's Avatar
Default Bow tie blocks
Found some tall d e ck motors that were built an y pros or cons beside longer push rods intake manifold distributor e being higher ???
tripps is offline
Old 02-20-2026 | 10:03 PM
I have a old gm tall deck and they are fine, water pumps starters alternator brackets are the same, I run aluminum heads with retro fit roller lifters so had to measure the push rod lengths, they make tall deck intake manifolds( all single plane) a lot of the tall deck intakes are machined for standard bbc distributors, you can also get tall deck blower manifolds, I have had no fitment issues with mine. It’s an old tall deck truck block, 4 bolt mains and had no real problems doing stroker 496.
496blower is offline
Old 02-20-2026 | 10:06 PM
If you get an intake not machined for standard distributor they make slip collar ones that you can use, if you use the spacer plates to run a standard deck intake manifold you would definitely need a slip collar distributor.
Old 02-21-2026 | 08:12 PM
Rookie's Avatar
Exhaust location? I thought it needs to be moved up and out ~1/2"
Rookie is offline
Old 02-21-2026 | 09:44 PM
tripps's Avatar
Default Bo tije
I got enuf wiggle room with my e x
tripps is offline
Old 02-21-2026 | 10:29 PM
I installed my engine the put exhaust in, so I had no issues, the blocks are I think .400 inch taller so it should only move up the exhaust a little, guess if your running twins and they are super close together it could cause an issue.
