-   -   Mirage Props Blowout/cavatation (https://www.offshoreonly.com/forums/general-q/38753-mirage-props-blowout-cavatation.html)
OPIE272 12-18-2002 09:29 AM
Jayl13
I have a 272 SR-1 formula with twin 330's putting out 350hp with 25p Mirages turning tops in.
If I trim tabs and drives full down and push throttles up to 3000 RPM's and leave them there. I can't trim the drives and tabs fast enough to keep the bow of the boat from digging in.
You need to get some prop work done in a serious way.
Sounds like Houstonprop is on the right track.
Oh BTW I top out 1/2 tank of gas and 3 adults runs 71.5 on GPS.
Hope that gives you some #'s to work with.
I was thinking that the Formula is also heavier so your #'s should be better
fountain27ho496 12-18-2002 11:21 AM
houstin
Darin, I believe merc says 4800-5000, the tests I've read seem to be running best at the upper end.
Just don't want to be up against the limiter, 5000 would be good
then on a cold day it would still hit 5100
thanks.... john
HOUSTONPROP 12-19-2002 12:15 AM
Re: Re: houston I need lift off...
Originally posted by HOUSTONPROP
Fountain27ho496, where exactly do you want the RPM's to be at WOT. Let me know I can dial you in.
John what I recommend is to rework the prop to obtain the correct rpm and get you more speed this can be done /let me know:cool: sorryI am so short but I have had a16 hr day so far and not done yet. you can call thursday if you like .:)
HOUSTONPROP 12-19-2002 12:29 AM
Originally posted by OPIE272
Jayl13
opie 272 Thankyou I can't do it by myself ,I appreciate your help.Darin:D :D Happy Holiday!!!!!!!
Shooter 12-19-2002 06:39 PM
Hey Panther,
You wouldn't happy to be the red one in Little Silver, would you?
JUSTONCE 12-20-2002 11:37 AM
HOUSTONPROP: Thanks for all your help my prop going on the truck to you today.:D
Martin.
FloridianSon 12-20-2002 02:21 PM
Darin thanks for the the help and fast turn around time.I will try it out when I get back.:cool:
Panther 12-20-2002 05:04 PM
Shooter,
That would be me! Actually it is Red Bank, not little silver.
Who are you?
hmm, Baja???? Is that Baja Joe?
HOUSTONPROP 12-20-2002 11:21 PM
HAPPY HOLIDAYS EVERYONE!!!!!!
I would like to Thank everyone very much and wish you all a great Christmas/Darin&KIM:)
SeaRay Jim 12-21-2002 11:26 AM
Kind of off topic but....
Darrin,
What's your thoughts on the finish of the prop; polished or satin? The assumption I've had (based on others opinions) is that polished perform better because the are smooth (and of course they look good). I've recently heard that a satin finish actually perform better.
So, if you labbed 2 of the exact sames props in the same application and give one a polished finish and the other a satin finish, besides appearance, what differences might there be?
