Mirage Props Blowout/cavatation
Jayl13
I have a 272 SR-1 formula with twin 330's putting out 350hp with 25p Mirages turning tops in.
If I trim tabs and drives full down and push throttles up to 3000 RPM's and leave them there. I can't trim the drives and tabs fast enough to keep the bow of the boat from digging in.
You need to get some prop work done in a serious way.
Sounds like Houstonprop is on the right track.
Oh BTW I top out 1/2 tank of gas and 3 adults runs 71.5 on GPS.
Hope that gives you some #'s to work with.
I was thinking that the Formula is also heavier so your #'s should be better
Darin, I believe merc says 4800-5000, the tests I've read seem to be running best at the upper end.
Just don't want to be up against the limiter, 5000 would be good
then on a cold day it would still hit 5100
thanks.... john
thanks.... john
Originally posted by HOUSTONPROP
Fountain27ho496, where exactly do you want the RPM's to be at WOT. Let me know I can dial you in.
sorryI am so short but I have had a16 hr day so far and not done yet. you can call thursday if you like .
Originally posted by OPIE272
Jayl13
Jayl13
Happy Holiday!!!!!!!
Darrin,
What's your thoughts on the finish of the prop; polished or satin? The assumption I've had (based on others opinions) is that polished perform better because the are smooth (and of course they look good). I've recently heard that a satin finish actually perform better.
So, if you labbed 2 of the exact sames props in the same application and give one a polished finish and the other a satin finish, besides appearance, what differences might there be?
