Crossover and thermostat housing install?? >
Old 12-18-2002 | 07:02 AM
Default Crossover and thermostat housing install??
Just want to make sure I got it right......I am installing a waterpump crossover....from stainless marine that eliminates the circulation pump and a stainless marine thermostat housing that eliminates the Mercury housing that has 6 hoses going into it!!
The new one only has 2 hoses going to it......anyon know where I can get a diagram showing the plumming or explaination of how to do it. Stainless Marine has nothing in writing.....
Thank's
Mike
Speed H2O is offline
Old 12-18-2002 | 08:51 AM
What kind of exhaust manifold are you running?
Gary
Gary Anderson is offline
Old 12-18-2002 | 09:23 AM
Oh yeah, I forgot to ask:
1) Is there a bypass?
2) Are you using a thermostat?
3) Is it a pre-heat system?
Gary
Old 12-18-2002 | 12:53 PM
Gary,
Stock HP500 carburated, yes the thermostat housing and the crossover connect together via a smaller fitting guess thats the bypass. Stock Mercrusier by Gil..manifolds with the stock stainless risers...at the bottom af the manifolds there is a series of t-fittings that are connected together with hoses.....guess thats the pre-heat?
Mike
Old 12-18-2002 | 01:15 PM
Preheat routes the water through the exhaust manifold befor the engine. You would have an odd looking splitter that bolt where the circulating pump used to. I'm guessing you have the regular S/S fitting with 1 1/4" inlet that splits to two pipes that bolt to the water pump inlet holes. There is also a small 3/8"? oultet on this that point up.
Remove the water pump, thermostat housing, the 1 1/2" hose that connects these, and the 4 hoses that connect the Thermostat housing to the bottom of the manifold series of Ts and to the T in the hose between the maifold and riser. Don't remove the series of Ts at the bottom of the manifold.
Replace the manifold to riser hose and T with a single 1 piece hose. The T wont be needed. Gil sell these hoses.
Bolt on the crossover and thermostat housing with a 143 degree thermostat.
Routing:
Inlet, strainer, water pump, coolers, then to the 1 1/4" inlet of the new crossover. Connect the small tube between the Xover and thermostat housing. You need a couple hoses (3/4" or 1", cant remember) to connect the 2 oultlets of the thermostat housing to the previously used inlet at the bottom of the manifold. That's it.
Gary
Old 12-18-2002 | 05:56 PM
Gary,
THANK YOU!!! got it now
Mike
Old 12-19-2002 | 12:45 PM
Quiet Storm's Avatar
Mike
Can you post a picture of that setup when you are finished? I had to do the same thing with my 454 mags after putting on Whipples on and have always wondered if I did it right. My exhaust seems very hot to me.
Roger
Quiet Storm is offline
littledcsrodshop
Wanted
3
06-19-2008 08:56 AM
powercat
Wanted
0
01-17-2008 08:15 PM
mwillis
2
04-09-2006 12:00 PM
Rambunctious
5
05-17-2004 12:20 PM
SLINGSHOT
04-23-2002 10:47 PM
