Best MI Motor rebuilder . . .
How Deep are your pockets? Sterling!!!!!!Wesco Industries (Dave Wesseldyke) or if your a tight ass like me do them yourself!!!
If your boat has a sail do you ride a horse to the ramp?
Hey dyno....how about Double D/Team Chaos?? They/We do pretty good work.
Bruce Wolfie of:
Wolfie's Compition Engines is Awesome.
He built engines for several of my friends.
Stands be hind his work.
Del Sol is on the board here and he
bought a set of Wolfies engines from
a friend of mine. Still running
Strong in a big 40' Scarab.
Wolfie is in Baroda Michigan, not
sure I spelled that right. Anyways
right by St. Joe.
Good Luck
Cougarman
right by St. Joe.
Good Luck
Cougarman
"Baker, Crockett, Katech, Sterling", Wow, thats some heavy hitters. All are established top notch builders. My son worked about 2 years at Sterling, and has been with Katech about 4-5 years now. If you go to either Sterling or Katech, you better have deep pockets.
Jomar, has also been around a long time and has alot of experience in performance marine. Millennyum, might be your best bet. I know he has done considerable work for 26Scarab, and he seems to be very consciencencious. He is close, next to Beacon Cove, plus he is a boater himself! I don't think Sparky at Viscious does engines anymore, but he is so entrenched in the loop around here he may be a good one to get a referral from.
Good luck
Good luck
A couple of friends of mine had engine work done at Shipwreck Marine and were pleased with the work. Not close to you, though. They are in Detroit, near Jefferson.
I believe there are several shops in Michigan that do a good job.
Bruce Wolff (Wolffie) got his start with John Lingenfelter and eventually became one of his right hand men. Wolff builds & tunes a lot of offshore stuff for guys in Indiana & Chicago areas. His shop is located in S.W Michigan: (269) 422-1090
