Drive Shower Choice >
Drive Shower Choice
Drive Shower Choice
Old 12-22-2002 | 08:06 AM
Keith's Avatar
CBPBA's Walmart Greeter
Hmmm, didn't see him ask about inspection cap mount. In that case he's right, or at least I'm not aware of one that would work. The Halo I think has 10 dump ports to flood the area, I would definitely recommend he speak with Simrek to see what they think in that case.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 12-22-2002 | 10:49 AM
I have the same problem with my latham,only the cover is made different where the steering rams connect its raised higher. I have a pair of eddie marine I'm try to make work but I don't see it happening. I thought Latham made a shower that went thru the opening in the of top the bracket on the inspection plate. I haven't really seen much info on it and wonder how much water would get thru.
Laktrash is offline
Old 12-22-2002 | 11:16 AM
Donzi38ZX's Avatar
I have sent an e-mail to Simrek. I'll report back with what they have to say.
Steve
Donzi38ZX is offline
Old 12-22-2002 | 10:32 PM
Donzi38ZX's Avatar
Here is the response I received from Simrek.
Steve,
Happy holidays. Yes we do. It's a custom Summit design that has 11 dump ports. It bolts to one of the top studs. The cost is $129.95 plus $9.95 for S&H.
Thanks,
Paul Kermis
Pres. Simrek Corp.
Old 12-23-2002 | 04:53 AM
Keith's Avatar
Thanks for the follow up, always learning something new.
K2
Keith is offline
Old 12-23-2002 | 10:51 AM
Steve, That price was list. I didn't know that you were OSO. If you can wait untill the Feb./March time frame, they will be discounted same as last year for you guys.
Paul Kermis is offline
Old 12-25-2002 | 09:08 PM
rpm
Default Drive Shower
Here is a pic of what I can do for you. $149.95 Shipped to you. It has a shield that goes underneath the Latham cap that captures the water and forces it down the sides of the drive where its effective. The shield is stainless steel so there will be no corrosion issues. It works very well. Money back if you are not satisifed.
Rod
Old 12-26-2002 | 06:48 AM
SIMREK no doubt!
Vyper340 is offline
Old 12-26-2002 | 03:33 PM
check these out: http://jlbco.hypermart.net/driveshower.htm
enticer is offline
Old 12-26-2002 | 08:47 PM
SeaRay Jim's Avatar
Paul, I bought mine from you last year when you discounted them. Are you going to discount again this year to the CL forum folks as well? Seems like last year you mentioned getting some flack from your retailers and you weren't going to be able to do it anymore.
Either way, discounted or not, they are more than worth it even if you get them for simply keeping the drive clean.
SeaRay Jim is offline
