Lets Build the Perfect 540
#31
Originally posted by bobby daniels
HEY RACHET /// 850HP ON PUMP GAS IS LOFING WITH THE 565 ABOVE ,JUST LOFING ////I'VE DONE 16 MOTORS 565'S
I'd like to build a set of naturally aspirated 565's (in the future) to replace my 355's in my 31 scarab. Have all of the ones you've done been NA ?
#35
NOPE BLOWERS ,ITS THE WAY TO GO IN THE RPMS WE RUN 6K AND LESS AND NOT BEAT THE MOTOR TO DEATH BEING NA !
SORRY IF I POSTED WRONG OR NOT CLEARLY ,BUT I'LL HELP ANYWAY I CAN ,INFO,PARTS ,ECT.
My apologies, weak link between the chair & keyboard
Thanks again !
#36
I'VE DONE A COUPLE OF 540'S AND 565'S ON THE DYNO AND NA ALWAYS GET 720 TO 740 WITH A BARRY GRANT 4500 AND 9.5 COMP AND A 288AR8 COMP CAM .THIS IS BELOW 5600RPM ,,YOU NEED ISKY LIFTERS AND COATED SPRINGS PREFERED WITH OILERS ON SPRINGS TO BE TROUBLE FREE ,BUT CHIT ITS A HOSS OF A COMBO !!! THEY WERE N/A AND AGAIN A HOLLY TERROR
#37
I`ve been thinking about this topic. If you are going start with a tall block and you will have to purchase a crank, why would someone build a 540 when you could use a 4.5"stroke crank and bore the block to 4.5" and make a 572"???
What are the advantages/disadvantages over 540 vs the 572???
I`ve been playing around with the numbers on my desk top dyno and a n/a 572 with a single plane intake, Holley dominator makes around 700hp @5200
#38
Hi, Biggus,
The 572 is a very good engine. The 540 is also a very good engine. I favor a 565-4.600" bore X 4.25" stroke with a 6.8" rod.
This has been a very good combination for me. You get less side loading with this combo, you unshroud the valves very well and get excellent power, especially with a blower. The 572 might be my choice NA., but with a blower the 565, I think, is a better overall, long life combo. With a blower, especially a Whipple set up, you will make more power than a Dyno 2000 predicts, especially at anything less than about 5,000 rpm.
#39
Sorry I have been MIA the last two day, I have been working late. Back to the crank. It looks like the 4.25" stroke crank is the best choice, due to side load issues as were mentioned above. Who do you all think makes the best crank for a engine like this?
Jon
Jon
Put your best foot forward!
