Synthetic drive oil >
Synthetic drive oil
Synthetic drive oil
Old 01-15-2003 | 02:35 PM
BajaBennett's Avatar
Question Synthetic drive oil
Guys, I need your help! I am thinking about changing to a synthetic drive oil. Which brand and what weight has worked best for you? I am running Bravo I drives in 302 Baja with 502 Mag MPI's. any thoughts would be appreciated.
Dail
BajaBennett is offline
Old 01-15-2003 | 03:39 PM
Wally's Avatar
Were doomed!
I ran RedLine ShockProof Heavy in my TRS drives as per recomended by RedLine....the biggest difference i noticed was during oil changes you had next to none of those metal dust fragments on the magnet.....and less of the chaulking from the heat on the drive after hard runs.. Also when shifting into gear it seamed like it went smoother and not suck a hard "clunk"....not sure if that was the oil taking up any extra play there may have been inbetween the gears or what but it was noticible...
-Wally
Wally is online now
Old 01-15-2003 | 05:02 PM
DanB's Avatar
Charter Member #71
Anyone use AMSOIL??? or Royal Purple???if so what wt.?
Dan
DanB is offline
Old 01-15-2003 | 06:09 PM
I ran Amsoil 80w90 GL4
last year in bravo 1's, behind
500's.
Drives seemed to shift smoother,
and less chalky build up on the drives,
compared to merc. hi perf. lube.
my .02
jt
JaayTeee is offline
Old 01-15-2003 | 09:29 PM
rbtnt's Avatar
Here's a link to a thread with 66 posts talking about gear lube. It ended a couple of weeks ago. There is some good info, but no agreement on what is the best to use.
http://www.offshoreonly.com/forums/s...threadid=39602
rbtnt is offline
Old 01-15-2003 | 09:59 PM
mcollinstn's Avatar
I just mixed up a batch of Torco, Amsoil, RoyalPurple, Redline,Quicksilver, Mobil, and K-mart gear oil.
I expect that it will have the best characteristics of each component and will probably enable your drive to last forever and handle unlimited horsepower.
Give me a call and I will send some right out to you...
mcollinstn is offline
Old 01-16-2003 | 07:27 AM
GregP's Avatar
I run Royal Purple in both the drive (TRS) and the trans. So far so good. I'd have to check, but pretty sure the drive is using the 75-90. I think MrGadgets also uses Royal Purple in the drive.
-Greg
GregP is offline
Old 01-16-2003 | 08:43 AM
Amsoil's 2000 series currently. Have been using Amsoil products since the early 70's and have never had a lubrication related failure. --- Jer
jpclear is offline
Old 01-16-2003 | 04:39 PM
Reckless32's Avatar
Rough Seas Lie Ahead
I use Mobil-1 from Advance Auto....
Reckless32 is offline
Old 01-16-2003 | 05:29 PM
KAAMA's Avatar
About a month ago we beat this subject to death! I'll see if I can bring it to the top!
KAAMA is offline
