merc II transmission >
Old 01-30-2003 | 05:05 PM
CHAOS REIGNS's Avatar
Default merc II transmission
is there a direct replacement for this tranny? or can someone recommend a good rebuild shop?
I want it to be able to handle 600 hp.
I don't mind sending it off -- if it is done right
thanks
Mark
CHAOS REIGNS is offline
Old 01-30-2003 | 06:23 PM
rws's Avatar
rws
I have ran these trans for years.You can replace it with a Borg warner transmission,But you will have to move the engine approximately 5" forward .I have the whole Borg warner 72c setup (trans, Bellhousing, Starter, coupling ) if you are interested.As far as the merc II trans handling 600 hp that is asking a lot even with adding a clutch plate and cyrogenicly treating the gerotor pump .Tom Huber in Franklin Tenn. is reputable as is Marc Berman At Bam marine 954-321-0649.
Rob
rws is offline
Old 01-30-2003 | 06:30 PM
i was hoping to not have to move the motor -- but i don't suppose thats a big deal since i am pulling it anyhow.
how much are you looking for your setup? and what kinda hp can it take -- how fresh is it?
thanks
mark
h2oboy
38
01-16-2009 07:17 AM
overdrive75
Drives and Lower Units
2
08-08-2007 04:41 PM
pipnit
0
08-09-2004 03:41 PM
CHAOS REIGNS
11
07-15-2004 12:27 PM
seacraft23
4
05-15-2004 08:16 PM
