Help With Prop >
Help With Prop
Help With Prop
Old 02-11-2003 | 05:47 PM
HOUSTONPROP's Avatar
Default 23 mirage
I have a 23 mirage if you want to try it out just call me and I will send it to you /Darin
HOUSTONPROP is offline
Old 02-11-2003 | 06:09 PM
blue thunder's Avatar
Wow, how can you beat that deal! That is very reasonable of you Houstonprops. Do you by chance have a couple bravo1s or hydros I can test run in the spring?
BT
blue thunder is offline
Old 02-11-2003 | 06:25 PM
82LAVEY's Avatar
All of you have been great thanks had to laugh the way SpectreBoy tests the rotation of prop OUCH
82LAVEY is offline
Old 02-11-2003 | 06:43 PM
Thumbs up BRAVO ONES
BT
NO PROBLEM JUST CALL WHEN YOUR READY AND WE WILL FIX YOU UP WITH A SET TO TRY OUT .
Old 02-11-2003 | 07:11 PM
Will do... thanks Houston !
(makes me feel like an astranaut when I say that hehe ).
BT
Old 02-11-2003 | 07:43 PM
cool we will be here!Darin
Old 02-11-2003 | 08:31 PM
Rambunctious's Avatar
82lavey
my understanding is the 330's (like my 1988 twins) peak power range is 4200-4600. the 454 mags (365hp?) are redline at 5000.
mine are proped at 4600wot . it you take many people on board frequently , you may want to spin to 4800 by yourself. if your "load" is pretty consistent, then maybe set up for 4600.
bottom line. trial and error around the best guess (23")
let us know
Rambunctious is offline
Old 02-11-2003 | 08:44 PM
checkmate981
I dont no if you checked this but make sure you check your tachometer .I had A tach that was off 300 rpm's at wot.
Dave
Old 02-11-2003 | 09:27 PM
Thats where the 100 PERCENT GUARANTEE COMES IN!
Old 02-11-2003 | 09:42 PM
checkmate981
HP
100 Guarantee is Great.I Will probely be calling you in the spring.
Dave
