ALPHA Questions >
ALPHA Questions
ALPHA Questions
Old 02-11-2003 | 07:43 AM
Default ALPHA Questions
Current- 1987 Baja Force 280 with twin 454s and aplha R/H drives
Found a new L/H Alpha One Gen 2 with 1:47 gear ratio.
Will the gen 2 work with my other alpha?
Anyone know what my current ratio should be?
What is involved to change the 1:47 ratio? Cost?
Thanks, Jim
JimmyBaja is offline
Old 02-11-2003 | 11:39 AM
JON242
The Gen 2 won't bolt up to your current gimbal and transom assembly. You would need to replace that as well. You could probably pick that stuff up for a couple grand.
Old 02-11-2003 | 10:18 PM
Jon,
Do you have first hand experience with trying to convert the alpha 1 to a gen 2? Another source stated they thought it would bolt up.
Anyone out there have experience? Can you bolt up a gen 2 to an aplha 1?
Thanks, Jim
Old 02-12-2003 | 05:00 AM
Jimmy, the big block alphas usually had 1.33 ratios because of the added torque. I am fairly sure that the a1 and a2's will not interchange, but regardless of that a big block will have prop issues with the 1.47 and would bust it more quickly than you would want. If you are keeping the boat for a while you may want to consider a swap to bravo1's. Good luck with it.
bucky is offline
Old 02-12-2003 | 06:02 AM
Offshore Addiction
your talkin alot of work,lot of parts convertin,it may be a little simpler to take the counter rotatin parts out of the gen 2 and puttem in the alpha housing!!!!!and the alphas used a 1.32 ratio for big chevy and older ford!
Old 02-12-2003 | 07:51 AM
Thanks Guys
Is the lower the same? If so, couldn't I just switch the lower? I'm told that's where the counter rotation actually happens?
Jim
Old 02-12-2003 | 09:03 AM
Offshore Addiction
you have to switch the inners,carrier and gears!
srracer
2
04-20-2006 03:49 PM
David Stotz
19
12-02-2005 06:22 PM
Red Stripe
7
05-28-2002 06:48 AM
BAD-HABIT
8
01-21-2002 06:21 PM
