Teague Tips with B&M 250 SC >
Old 02-13-2003 | 04:12 PM
bobby daniels
Originally posted by cpqtim
That sounds reasonable. Yes, the cam will probably be a 741. Package not assembled yet and I have not selected the cam. I was going to get some recommendations from Crane and then post them here to see what the board thinks. US1 Fountain ran the 741 with good results so I did not want to deviate from his setup without a good reason. From reading about the crossover setups it seems there may be some considerations with water pressure. Not quite sure how to address this yet. Thanks for the info.
Tim T.
there are alot of ways( mech.water dumps Ect. ))to control pressure don't let that bother you ,The 741 is a killer cam ,you can pick upabout 45hp using a comp that 1500 has custom ground and I've used alot of ,contact him if interested
Old 02-13-2003 | 04:18 PM
Jerry,
I'm all over that one! Got the shiny object in the downstairs garage, Dan and I are getting the jet and PV numbers. Just a came upstairs to get a pencil. Looks like 124's in front. I better start tossing 20's in the jar for gas! Did you happen to replace the top oil fill plug? The manual says that the fill plug has a small hole in it for a vent, the plug I am seeing has no hole. Oh well, it worked all this time.
Tim T.
BadDog is offline
Old 02-13-2003 | 04:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Tim, I have already persued the plug conscern.
If you run the plug with the hole, I think it was around .020, you will get a nice film spray on the bottom of your hatch and all over the top of the blower. Ain't cool! I talked with The Blower Shop about this 2 yrs ago thinking the front oil seal was bad. They said it was from a slight pressureizing of the front housing when you get into the boost. The seal is a single lip orientated to keep the oil in, so naturally little pressure on the back side will blow past it. Holley/ B&M now recommended to use the solid plug and just change the gear oil at least once a yr, according to Blower Shop. You'll be fine as is.
I think all 4 corners have same jetting.
Jerry
US1 Fountain is offline
Old 02-13-2003 | 05:34 PM
OK, on the plug. Documentation was probably for automotive. My guess is that in a car there is enough air blowing around under the hood to carry it away. Checked the rear jets, they are 134's with blocked off PV. Did you ever consider installing the rear PV and boost referencing it? That would be a question for the blower shop I suppose.
By the way that was a really cool box of spares, already broke into it for a friends Holley.
Tim T.
BadDog is offline
Old 02-14-2003 | 04:35 PM
Ginger or Mary Ann?
Tim T.
Tim,
Nope, never considered anything else once it was done. It wasn't broke, and I couldn't see how it could have ran any better, so left it as you have it. Those jets do sound a tiny large, huh? Like I said before, my transom was always spotless. Maybe Blown and 1500 may have better thoughts. Getting out of my league as far as changes. The new red metering gaskets are for the carb as is, I just never installed them. They do have a couple of extra holes from the installed ones, but If you study the flow passages, you will notice they are more or less blind holes. The green gaskets are from when Bruce referenced it and installed the JER metering blocks. I thought the red would go with the powdercoating better. It's all about looks!
Old 02-14-2003 | 05:09 PM
birdog's Avatar
How do you guys chage the oil in these Blowers ? Suck it out the
bottom hole ?
birdog is offline
Old 02-14-2003 | 05:10 PM
birdog's Avatar
Oh....Back to the tips.....
Any deals on 2 pair of clamp on switchables ?
birdog is offline
bsc
Swap Shop
11
08-11-2008 08:46 AM
hoozeyurdaddy
2
05-21-2008 07:53 PM
AO31
Wanted
1
03-23-2008 11:11 AM
CNC
3
11-17-2004 06:36 PM
