exhaust tips >
exhaust tips
exhaust tips
Old 02-19-2003 | 06:13 PM
Cool exhaust tips
does anyone have tips or tricks in removing the thru hull tips that are factory installed i blew the internal flapper out is there one brand of tips with internal flappers that are better than another
thanks
bo
carreraboat is offline
Old 02-19-2003 | 08:44 PM
CAP071's Avatar
pulling them out is No problem I did mine in about 10 mins R/R There are different 1's though some are cheap with the flappers inside as well as the plating. Honestly You get what you pay for with them
CAP071 is offline
Old 02-20-2003 | 12:50 PM
I had the same problem with my exhaust tips. Getting the old ones off was very difficult! Hammering from the inside out, took many hard hits. When I was finished removing, my Gel coat was cracked around the opening. I had to re-gel the openings. I installed tips from stainless marine with the metal/weighted internal flappers. Have not had a problem ever since!
FBRONCO is offline
Old 02-20-2003 | 03:03 PM
Truckin
Default Easier than you might think!
Install a two by four about 3 feet long into the tip (from the outside of the boat) and pry it up and down and it will come loose without damaging the gel coat.
Dennis Moore
Old 02-20-2003 | 03:39 PM
Wally's Avatar
Were doomed!
if silicone is the problem your running into then go to a hardware store and get some thin piano wire...you can snake it down inbetween the tip and the boat and cut the silicone. it should be alot easier to get them out after that
-Wally
Wally is offline
Old 02-20-2003 | 07:39 PM
thanks guys going to try and tackel it this weekend
bolgna
4
01-23-2008 06:23 PM
cowisl
01-16-2008 03:12 PM
thunderdan
01-07-2006 07:45 PM
87 glass
6
05-02-2004 01:20 AM
CAP071
2
05-04-2002 11:31 AM
