Fuel Gauge Jumping >
Fuel Gauge Jumping
Fuel Gauge Jumping
Old 02-22-2003 | 02:41 PM
Fast Forward's Avatar
Question Fuel Gauge Jumping
At the end of the season my fuel gauge began to jump on occasion
In the downward or empty reading area. I pulled the dash to check for possible loose
connection but found nothing. Will check connections at the tank this spring, but also am thinking maybe the sending unit in the tank may be going. Any thoughts???
Fast Forward is offline
Old 02-22-2003 | 04:04 PM
Blackhawkdn
there is a possiblity that the sending unit in the tank is sticking, this happens once in a while. also check the tank ground for a good clean connection, hpoe this helps
Old 02-22-2003 | 10:02 PM
mcollinstn's Avatar
Sending unit.
Might get away with opening it up and using contact cleaner on the windings.
If you're going to that much trouble, though, get a new sender.
mcollinstn is offline
Steve_H
4
02-03-2007 11:58 PM
ComfortablyNumb
5
05-22-2006 10:20 PM
snopro13
6
05-12-2005 01:25 PM
JROMY
2
07-23-2003 07:29 AM
502KC
Fountain
6
07-08-2002 07:59 AM
