Question - intercoolers >
Old 03-17-2003 | 03:38 PM
bobby daniels
Tomcat how does the whipple innercooler work in your opinion compared to the others ????
Old 03-17-2003 | 04:15 PM
I've seen dyno tests on certain brands that look great on a quick acceleration test, but based on there construction once they get heat soaked from running they will not cool as well, won't make the same type of power.
RumRunner is offline
Old 03-17-2003 | 05:30 PM
bobby daniels - I have no personal experience but I have talked to Dustin about their cupronickel intercoolers, and they are more efficient. In other words, if you compare two intercoolers of the same size and shape with the same water flow, the cupronickel one will remove more heat than the aluminum one.
When you say compared to others I assume you're talking about their intercooler/intake manifold for Roots blowers. From the pictures I have seen, it looked like they opted for a shallower intercooler core with a larger cross-sectional area. As long as you balance flow across this larger area, this geometry helps a lot with both cooling and pressure loss.
RumRunner - You are right. When we tested NEVRENUFF's Procharged 454, we only tested for 30-45 seconds at WOT. I couldn't ask Paul for more than that. We proved our gains in HP over the standard intercooler, but temperatures from both intercoolers were still rising.
When you start the test, the intercooler is uniformly cool because of the water running through it. But as the charge air warms it up, the exiting air temperature rises as does the exiting water temperature. This lag is called thermal inertia or thermal transition. It helps you for short bursts of power. I was sorry that we didn't datalog these climbing temperatures because we could have seen how the curve was levelling out and made an estimate of final temperature at equilibrium.
Now here's a thought for you. When the air temperature exiting the intercooler warms up, the air density at the carb decreases. So the carb jetting becomes richer. This is a built in safety valve on a blowthrough carb. As long as you don't get too hot and cause detonation.
tomcat is offline
Spirit38
3
03-02-2008 09:31 PM
Buddy OO
04-07-2007 03:47 PM
WHODATHOUGHT
1
01-26-2004 04:12 PM
SLINGSHOT
10-04-2002 04:04 PM
