Hour Meter connection >
Old 03-28-2003 | 03:17 PM
RMPRam's Avatar
Default Hour Meter connection
I'm finally getting around to hooking up a pr. of hour meters to my motors.
One post on the meter is for ground and the other is a + terminal that I want to connect to the coil (the meters are mounted in the engine compartment).
Anyone see any problem in going directly to the coil for the signal to the meter? I'm worried that connecting directly to the coil will "lessen" the signal to the MSD and thus weaken the spark to the motor.
Any suggestions??
RMPRam is offline
Old 03-28-2003 | 03:34 PM
Official OSO boat whore
No, this won't be a problem. If you should happen to leave your ignition switch on, your hour meter will continue to run-even if the engine is not running. If this will be a problem, wire the meter through a hobbs switch.
Cord is offline
Old 03-28-2003 | 04:09 PM
Tantrum's Avatar
How does the hobbs switch work?
Its always bothered me that my stereo is adding hours to my motor!
Tantrum is offline
Old 03-28-2003 | 05:12 PM
Payton's Avatar
Charter Member #927
Your stereo should be wired to your Assesory side of the switch, your hour meter should be wired to the on side.
I have a separate Stereo/ assesory toggle. It's not wired to the key.
Payton is offline
Old 03-28-2003 | 06:42 PM
RMPRam's Avatar
I called MSD after I posted my question and was told not to connect anything to the coil as long as I was using their 7 series box.
I was told to connect to the red (+) terminal on the box and I would get a 12v. switched signal.
FYI and mine.
RMPRam is offline
amarek
Baja
10
03-15-2008 08:02 PM
26sonic
02-25-2006 11:11 PM
Stormrider
02-08-2005 09:31 AM
Glenora
5
05-29-2004 07:44 PM
Raypanic
6
02-05-2002 10:25 PM
