Water Pressure sender location >
Old 03-29-2003 | 02:08 PM
GO4BROKE's Avatar
Question Water Pressure sender location
I am installing water pressure gauges and need to know the proper location for the electric sending unit. I also need to know if isolators are needed for protecting water pressure senders. The parts person I got them from thought so, so I bought them. I'm not so sure, if not needed I will save the isolators for when I buy fuel pressure gauges.
[img][/img]
GO4BROKE is offline
Old 03-29-2003 | 02:13 PM
GO4BROKE's Avatar
Here's pics of the goodies:
[img][/img]
GO4BROKE is offline
Old 03-29-2003 | 02:16 PM
jrz
T into the side of the block by the drain.
jrz is offline
Old 03-29-2003 | 03:21 PM
Mate 229's Avatar
Mines on port side of block below exhaust
Mate 229 is offline
Old 03-29-2003 | 06:29 PM
GO4BROKE's Avatar
Do you guys have isolators or are the senders screwed directly int the block?
[img][/img]
GO4BROKE is offline
Old 03-29-2003 | 07:02 PM
The block drain plug is a good place, but it is common for rust and other contaminates to get into the sender or hose in this location. It may be better to go into a plug in the intake manifold. I have mine in the block and so far had one false alarm due to a plugged line. If it happens again I will be moving my hose to the intake.
WETTE VETTE is offline
Old 03-29-2003 | 09:39 PM
mopower's Avatar
Toxic FORMULA
I have them on the t-stat housing now and in other boats without a problem .
mopower is offline
Old 03-30-2003 | 12:53 PM
MIKEHTMSR24's Avatar
Default I have two
one on the intake that is mechanical. I can just raise the hatch a couple of inches and see the liquid filled gauge. I also have the type you show in the picture.
A WORD OF CAUTION
This isolator is very heavy. I mounted mine on the side of the block also and the fittings have broke twice on me. Luckly I found the leaks in time. I finally mounted mine on the backside of the trim pump bracket and ran a hose from the block to the sending unit. Don't let a 50 cent part sieze your motor.
MIKEHTMSR24 is offline
Old 03-30-2003 | 02:02 PM
rbtnt's Avatar
Here is a picture of my isolator, sending unit and low pressure switch mounted on the transom. Follow MIKEHTMSR24 suggestion on mounting $.50 fittings on an engine. I have seen these fittings break where someone put a T on the block to hold an oil sending unit and oil pressure switch.
rbtnt is offline
Old 03-30-2003 | 05:48 PM
GO4BROKE's Avatar
Thanks guys, I probably would have mounted it to the block with the fittings, not thinking of the pounding it must take. I will definately fabricate brackets. Thanks again for the advice and the pic.
[img][/img]
GO4BROKE is offline
SCANDINAVIAN
0
06-10-2007 03:39 PM
East Coast B
21
01-27-2006 08:38 AM
ratman
4
08-02-2005 06:40 AM
DORaymond
5
06-07-2005 11:10 PM
Danny_Ocean
4
04-05-2004 10:47 PM
