Gen. VI Cam?? >
Gen. VI Cam??
Gen. VI Cam??
Old 04-02-2003 | 05:09 AM
convincor's Avatar
Default Gen. VI Cam??
Does a Gen VI 502 need a dronze distributer gear for a stock roller cam?
Do all aftermarket roller cams require aftermarket roller lifters?
convincor is offline
Old 04-02-2003 | 11:49 AM
bobby daniels
Depends on the way the cam was made as to the type gear it will say on cam card or call maker ,lifters depend on lift of the cam to be used ?????
Old 04-02-2003 | 03:20 PM
convincor's Avatar
Cam is Stock GM.
Old 04-02-2003 | 03:44 PM
bobby daniels
most of them require bronze gear ,if over 550 lift to 580lift generaly you need to change lifters
Comp cams has a composite gear that works on any cam and last for ever where as bronze wears
hope this helps
Old 04-02-2003 | 05:07 PM
convincor's Avatar
That helps.
Old 04-02-2003 | 05:13 PM
Which version of the 502 do you have?? Is it a 502/502 or is it a
marine 435hp base motor??
TomR is offline
Old 04-02-2003 | 05:30 PM
convincor's Avatar
it's the 435 base motor
TomR, Didn't I get Rex tips from you?
cdscarab
1
12-29-2007 07:19 AM
Sonic Scott
06-06-2007 05:00 PM
QUIKDECISION
4
07-17-2005 11:17 PM
PatriYacht
7
08-13-2003 06:19 PM
BadDog
19
09-18-2002 07:37 PM
