Crossover vs. Circulating Water Pump >
Old 04-07-2003 | 03:12 PM
Irish Mist
Default Crossover vs. Circulating Water Pump
I am looking for advise or installing a crossover vs. a circulating water pump on a pair of 454 engines. What are the advantages? What are the disadvantages? What is the preferred kit? How much should I expect to pay for it?
Old 04-07-2003 | 03:20 PM
LapseofReason's Avatar
If you have nothing now go with the crossover, the pump is just one more thing to go bad. They say the pump robs 20 hp, I would tend to think more like 5-10. The motor will run cooler without the pump so if you have high hp it will help keep them cool.
LapseofReason is offline
Old 04-07-2003 | 04:47 PM
Official OSO boat whore
That's the problem. Often the engines will run too cool. You might also have pressure problems. Many members have gone to the crossover only to have to solve more problems than they were trying to prevent.
Cord is offline
Old 04-07-2003 | 04:52 PM
birdog's Avatar
I run the pumps...No problems...Losing 5-10 hp on a boat is not
worth all the headaches with crossovers. Plus, The pumps help
eliminate any "hot spots" in the back of the motors
birdog is offline
Old 04-07-2003 | 07:20 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
On a stock motor, I would stay with the water pump vs the crossover route. Like Cord said, creating more unneccessary problems with pressures and temps. Are motors EFI?
Stock setups are hard to beat.
US1 Fountain is offline
Old 04-07-2003 | 08:48 PM
mopower's Avatar
Toxic FORMULA
Birdog's right. The circulating pumps help maintain a consistant temp. throughout the engine.
If they really weren't needed don't you think the factory would save a few bucks and eliminate them?
mopower is offline
Old 04-08-2003 | 06:53 AM
Offshore Addiction
the only reason merc installs them is because they come from GM with them already on the motor.....there is a couple MPH without them,you just have to make sure that you get your intake line secured properly,if your motor is EFI the youll need to run the T-stat version w/bypass,and there about 150 bucks!if there carbed then its your choice on the stats!if youve got serpentine belts then your SOL anyway!you cant put them on,only V-belt motors!
Old 04-08-2003 | 08:17 AM
liquid lounge
There is a guy that visits this board occaisionally that makes and sells alot of crossovers....when I wanted to buy one for my application [500hp EFI motor], he recommended against saying the circulating pump would be a better choice for my app. Anyway, I appreciated his candor so much, that I bought some manifolds from him!! Who is this guy? Brownie at Stainless Marine...call him, he will give you the straight scoop.
Old 04-08-2003 | 08:18 AM
THE DRIVE BELT FOR THE CIRCULATING IS A FRACTIONAL HP BELT. i DON'T THINK THE PUMP TAKES MORE THAN 1 OR 2 HP.
BROWNIE is offline
Old 04-08-2003 | 08:56 AM
Offshore Addiction
hey brownie,whassss up?I still need you to straighten that bent tailpipe on my warlock,after daytona I'll ship it to ya!
