Correct way to time a TB 5 for max performance? >
Old 04-11-2003 | 08:48 PM
ragtop409's Avatar
Default Correct way to time a TB 5 for max performance?
Ok, so I have a 1995 7.4L carbed motor. I am changing heads intake carb exhaust and distrib. (454 Mag) so I want to know the rite way to set the timming on this ignition set up. I have a digital advace light and have 1/2 an idea how to use it Any help will be great. Thanks Rag's
ragtop409 is offline
Old 04-11-2003 | 09:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You mean the basic way to use a light with advance????
If so, crank your motor up to 3000rpm and shoot your light at it. Turn the knob until the line on the balancer lines up with the 0 mark on tab. read the dial on light. Thats your max advance timing.
If not your answer to your question, disregard this.
US1 Fountain is offline
Old 04-11-2003 | 09:41 PM
ragtop409's Avatar
Sorry for my smart remark. I once read something about haveing to ground one of the wites on the TB 5 to get the corect timing? does this sound right. Just dont want to have problems. Rag's
Old 04-12-2003 | 09:17 AM
Ground the purple and white lead that has a a plug in the end of it. Then time it like a standard ignition. Otherwise it always hunts for "mean best timing" and the spark is constantly moving around.
bobl is offline
Old 04-12-2003 | 07:39 PM
ragtop409's Avatar
Thanks That is what I was looking for. Rag's
Old 04-12-2003 | 08:26 PM
rjcardinal's Avatar
You say you will be using the distributor from a 454 Mag. Did it come with the ignition module? If not you will need to get a module from a 454 Mag because the module from your 7.4 will limit your revs to 4700. The heads and intake will probably help some but to really wake the engine up you will need to change the cam. The distributor from a 1995 7.4 and 454 Mag are the same. All you really need to change is the module.
Ron
Ron
rjcardinal is offline
soinc
Drives and Lower Units
44
05-27-2009 09:20 AM
JB747
0
09-19-2007 12:02 AM
chewymalone
Prop Talk
10
06-23-2006 10:51 AM
ONESICKGLADIATOR
03-03-2006 09:02 AM
