Metal In Oil >
Metal In Oil
Metal In Oil
Old 05-01-2003 | 02:47 PM
JUSTONCE's Avatar
Default Metal In Oil
I checked my oil before changing it after I de-winterized last week and found some very fine brass looking filings on the dipstick. This will only be the 3rd oil change since the motor was built, I did not build the motor. I've never had a motor do this. wondering if anyone has seen this on a motor breaking in? I can understand bearings doing this on the first oil change but any burs should be off by now.
JUSTONCE is offline
Old 05-01-2003 | 03:03 PM
Luv-N-It's Avatar
Brass...hmmm... does not make sense. Come to think of it, the only thing I can think of that is "brass" is the drain plug on my block for water.
What else is brass with a motor where it could come from. Never even heard of bearings doing that before?
Luv-N-It is offline
Old 05-01-2003 | 03:12 PM
dyno's Avatar
Charter Member #655
I hate to be the berer of bad news but the Brass is the inner material in your bearings your bearings are toast.......I cant think of any other way you can get brass in the oil! I wouldn't run it or you may trash the crank or throw a rod...
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-01-2003 | 03:16 PM
Luv-N-It's Avatar
Sorry to hear that Martin. I know you have been working your ass off getting this boat ready for this season.
Luv-N-It is offline
Old 05-01-2003 | 03:37 PM
JUSTONCE's Avatar
When its ready , its ready. I am going boating period. If it gernades owe well.
JUSTONCE is offline
Old 05-01-2003 | 03:45 PM
Luv-N-It's Avatar
Just remeber son, if it happens at Alum, at least I'll be there to help tow ya in.
Luv-N-It is offline
Old 05-01-2003 | 03:46 PM
convincor's Avatar
Could it be bronze from the distributor drive gear if your running a roller cam?
I'd think you'd be hearing something, like a knock, if the bearings where that bad.
convincor is offline
Old 05-01-2003 | 03:48 PM
JUSTONCE's Avatar
Thanks man but you know if it breaks Its gonna be when I'm out in the middle of lake erie alone on a stormy day.
JUSTONCE is offline
Old 05-01-2003 | 03:54 PM
JUSTONCE's Avatar
I agree about the noise thing, it purs like a kitten. I never considered the dist. gear. That is a good point, I will check that.
Thanks for the input as usual guys,
Martin
JUSTONCE is offline
Old 05-01-2003 | 04:03 PM
convincor's Avatar
They say the bronze gears wear fast.
GM recomends a "melinized" gear for the new 502.
Part #gm 10456413
