too much water pressure >
Old 05-03-2003 | 09:31 AM
Cool too much water pressure
does anyonehave any input on putting extra selant on there head gaskets to help with extreme spikes in h2o pressure with there 100 mph plus boats was told by teague to put a small amount of silly cone around the water passages on the head and wipe down the gaskets with laquer(sp?) thiner anyone thoughts
carreraboat is offline
Old 05-03-2003 | 09:35 AM
also i have a water pressure dump set at 15psi this is a transom mounted water pickup once the boat gets above 85 the pressure gets above 30 psi and spikes sometimes at 80 psi at above 100
after the spike i have water in my oil
help
bo
Old 05-03-2003 | 10:28 AM
bobby daniels
Bo you said it right Teague and his silly puddy !! no don't wipe the gasket with thinner unless its copper !!don't put silly cone on it as most likly its weeping between the thin layers of the gasket
you have got to get the pressure down with the plumbing ,,,,you may need a bigger dump I don't know how yours is rigged but 30 is to much and 85 is crazy ,please fix it ,e-mail me how its plumbed ,(draw it) I'll gladly try and help
Old 05-03-2003 | 05:39 PM
if am not mistaken it goes from the transom to the sea strainer that is where the presure relief is the to the sea pump and out the exhaust there is one on the other side just for the innercooler
two seperatre wate systems both transom mounted
Old 05-04-2003 | 12:36 AM
candyman35's Avatar
You need a valve that can handle more volume. I believe Garry Grimes water dumps would work for you. He designed them to blow off pressure spikes quickly. His number is 770-475-5272. He is very willing to share information. I think on the race boats he used two valves. One is run off the sea strainer and the other just after the coolers before the water enters the engine.
Good luck,
Dan
candyman35 is offline
Old 05-04-2003 | 04:41 PM
MIKEHTMSR24's Avatar
Default I second that on the Grimes valve
I got one and it works like a champ.
You need all 1.25" dump hoses with a min. of 1" id. The valve is key also. Must be big enough to handle the quick pressure.
MIKEHTMSR24 is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
