Timing ??  for EFI Whipple users >
Old 05-14-2003 | 08:50 AM
Smitty's Avatar
Talking Timing ?? for EFI Whipple users
What is the maximum advance that you run on your EFI Whipple setup ??? I just installed one on my buddies 454 EFI and I set total advance at 30 degrees, but I think I can go to 34 degrees safely.
Thanks,
Dave
Smitty is offline
Old 05-14-2003 | 09:39 AM
bobby daniels
34 will work as long as you have good fuel an check knock sensors,,I use 34 alot
Old 05-14-2003 | 10:38 PM
SteveDavid's Avatar
Charter Member #1093
Dave,
I have 500 EFI with Whipples in a triple engine set up. When we put in new engines last summer (Chief engines, Fort Lauderdale) , we dynoed each engine at timing settings from 30 to 36 degrees, and found very little HP or Torque difference. (+/- 10 HP/ 15 lbs) We ended up at 32 degrees as a conservative midpoint. At 36 the knock sensors would kick in at full load, at 32 everything works fine thru the entire power band. We're running the Whipple intercoolers and 92/93 octane fuel. Engine temps never exceed 120 degrees and WOT water pressure is 18 lbs.
Hope this helps,
Steve
SteveDavid is offline
Old 05-15-2003 | 07:07 AM
Smitty's Avatar
Bobby and Steve,
Thanks for the input. I think I will set it at 32 degrees and play it safe. If it was my own boat I would stretch it, but I don't want to play with someone elses motor.
Thanks,
Dave
Smitty is offline
JIM H
4
05-16-2007 07:47 PM
hot water
2
12-19-2002 02:52 PM
John B
1
07-25-2002 12:29 PM
mxz800
1
06-09-2002 09:16 AM
fastedy
05-06-2002 09:09 AM
