Merc spline grease on propshaft? >
Old 05-16-2003 | 08:34 AM
Default Merc spline grease on propshaft?
After reading Scott's post a while back I realized thatI was using some wrong grease in the wrong places
I bought some of that Merc spline grease for the drive couplers, and someone also told me to use it on the propshafts as well.
Well, I opened the tube last night and the stuff seems to be too thin for use on the propshaft
Is it ok to use, or should I use 2-4-c instead?
THRILLSEEKER is offline
Old 05-16-2003 | 08:52 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Use the same marine grease used for the couplers, trailer hubs, and steering. It heavy duty, doesn't mix with water and bottom line, provides corrosion protection...
Reckless32 is offline
Old 05-16-2003 | 10:31 PM
KAAMA's Avatar
Maybe I am wrong, but I use Anti Seize on my prop shafts! It lasts a LONG time-----it hardly EVER comes/washes off!
KAAMA is offline
Old 05-17-2003 | 06:24 AM
HOUSTONPROP's Avatar
Question too much grease on prop shaft
if your prop has a rubber bushing ,too mch grease will work its way into the hub and cause it to slip.Darin (use anti seize)
HOUSTONPROP is offline
Formula Outlaw
05-16-2006 05:16 PM
chewy1955
2
02-27-2006 04:02 PM
nightmoves
0
01-22-2006 10:03 AM
Steve_H
10
02-13-2005 04:31 PM
