Bravo XR question >
Bravo XR question
Bravo XR question
Old 05-22-2003 | 07:42 PM
dhlaw's Avatar
Default Bravo XR question
My buddy has imco shorty lowers on his boat but it will be in the shop for a while and he offered to let me try them to see if they will improve my top end. Will imcos for a standard Bravo 1 fit into the XR upper?? Is the vertical different or the splines different?? ALso, can you just change out Flo-torq hubs to go from the standard to big shaft XR when swapping props??
Thanks,
Brett
dhlaw is offline
Old 05-22-2003 | 10:10 PM
Strip Poker 388's Avatar
Rob
i think the splin cupler is the same.
Strip Poker 388 is offline
Old 05-23-2003 | 10:27 AM
dhlaw's Avatar
ttt
dhlaw is offline
Old 05-23-2003 | 12:01 PM
Mr Gadgets's Avatar
Charter Member #601
Brett,
I believe they are the same. There is a standard coupler that connects the upper vert shaft to the lower vert shaft. It is the same for the XR and Standard Bravo. I see no reason for Imco to change that.
I believe the two would interchange.
Dick
Mr Gadgets is offline
Old 05-23-2003 | 03:22 PM
merlin540
yes they are the same
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
pax2you
3
09-18-2007 09:07 AM
xpx747
08-28-2006 03:55 PM
deboatmon
0
04-29-2004 02:24 PM
later
1
03-03-2004 09:13 PM
