my motors
Old 05-23-2003 | 04:22 PM
XCAV8's Avatar
Default HELP ...my motors
i took the heads off to ck everything out(make sure the mice didn't make a nest in there etc.)
the cylinder walls and pistons look good nice and tight,
so then we pulled the cam out of one, and 5 of the lobes have little flat spots ,not good..... think i'm getting 2 new cams and lifters now..... any help on cam selection would be appreciated....
these motors were supposed to be rebuilt by a local reputable machine shop about 6 - 8 years ago and have been sitting ever since(hence cking for the mouse nest)
the heads i have are 048 casting, they do not look like small peanut ports to me , and the valves look rather large also....
the pistons look to be 30 over as .030 is stamped in the tops
i will take pics of the heads and the pistons to see if someone here can help me figure out what i have....
the cams i was thinking of getting are Part No.: 315-132561 Category: Engines & Parts-Cams & Lifter Kits
Crane PowerMax Cams
Description: PowerMax - Fair idle, standard camshaft for Mercruiser 400, 405, 420 425 HP and 525SC-454 CID engines, applicable to 350, 365, 370 HP mildly modified engines with free flowing above water exhaust
DEG. DUR. @.050 INT / EXH 228
DEG. ADV. DUR. INT / EXH 298
DEG. LOBE SEP. 114
OPEN / CLOSE @.050" CAM LIFT INT /EXH 5 / 43
LASH HOT INT. EXH.000
GROSS LIFT INT. EXH. .530
pics will be up soon, any help will be greatly appreciated
XCAV8 is offline
Old 05-23-2003 | 05:43 PM
XCAV8's Avatar
pistons
XCAV8 is offline
Old 05-23-2003 | 05:50 PM
XCAV8's Avatar
Default valves in head
XCAV8 is offline
Old 05-23-2003 | 05:52 PM
XCAV8's Avatar
Default Intake ports
XCAV8 is offline
Old 05-23-2003 | 06:10 PM
XCAV8's Avatar
exhaust ports
XCAV8 is offline
Old 05-23-2003 | 07:29 PM
XCAV8's Avatar
ttt
XCAV8 is offline
Old 05-23-2003 | 07:42 PM
Check the valves to be sure they don't leak. If you are close to Highland NY, pm me and I'll give you a shop to call Paul
jaf302 is offline
Old 05-24-2003 | 07:50 AM
XCAV8's Avatar
help i need to order cams , need some good advice, will the cam i picked above work good yes ? no ??
XCAV8 is offline
Old 05-24-2003 | 08:59 AM
PatriYacht's Avatar
Those will work great. Better if used with a Holly 800 and an Performer Air Gap manifold. Smooth idle, good power. I've had Merc 400'S and 420's. Good running reliable engines.
PatriYacht is offline
Old 05-24-2003 | 09:21 AM
XCAV8's Avatar
ok here's what i have
merc 330's 030 over( fresh bearings and rings)
massive bassett offshore water jacketed headers long tube(5")
holly 850's with vac sec
orig q jets carbs
brand new dui distrib's
performer intakes
the above heads, (which i can't seem to idenifiy ???)
048 is the casting # are they large or small ovals??
i need to put these baby's together and get in the water.
40scarab thx (theres one for the cams i picked)
other opinnions Please.....
XCAV8 is offline
