closed cooling >
closed cooling
closed cooling
Old 05-29-2003 | 03:03 PM
duker
Default closed cooling
looking to install a closed cooling system. Give me the pros and cons and which brands are the best. Running in fresh water but installed a bbc thats fuel injected burning alcohol.
Old 05-31-2003 | 09:46 AM
mcollinstn's Avatar
If it's not a salt boat or a cruiser that sits in the water all winter, then there's little to recommend a closed system. The benefits are world's easiest winterization and complete protection from internal corrosion.
I'd stick with normal cooling (and I'm a guy who normally will recommend closed in a heartbeat). I just don't see any advantages in your application, especially since the heat exchanger takes up room and usually isn't cool looking.
mcollinstn is offline
Old 05-31-2003 | 05:24 PM
Vinny P's Avatar
I hate the winter!!
I have Mercs' closed cooling system. Works great. Fit real easy. I boat only in salt water. If you are interested, here is a link for after market closed cooling systems.
http://www.i-netmarine.com/fwc/fresh.htm
Vinny P is offline
Pokher Ace
8
10-17-2008 07:22 PM
Wodster69
8
04-23-2008 08:55 AM
sandcraft
10
04-05-2006 09:44 PM
2112
8
10-01-2004 12:34 AM
alter ego
9
03-30-2004 05:58 AM
