wet sanding question >
Old 06-04-2003 | 10:01 AM
KCHOTBOAT's Avatar
Charter Member #737
Originally posted by puder
does that just spin the pad like as if i put a polishing bit on a drill???
my waxer (both of them, air powered and electric) can spin in random orbit of non random orbit.
You should be able to rent one or you can use mine after you finish my boat.
KCHOTBOAT is offline
Old 06-04-2003 | 12:58 PM
puder's Avatar
speel chekk this fokker!
i'm not saying taht i was goign to use a drill, i was using it as a comparison of the way it rotates.
I already have 2 polishers. One is airpowerd and can spin in random orbit mode or switch to a spinngin mode. MY eletrci one does the saem thing. Is the spinngning motion what the tool you posted the link too does??? FYI i've used the electric random orbit to compound before and it worked well.
Pardon me, while I whip this out!
puder is offline
Old 06-04-2003 | 03:25 PM
later's Avatar
the buffers look like a grinder with a rubber backing and wool pad the air buffers came out many years ago and were ok for the lacquer days but dont have the grunt for ureathanes and gelcoat i would start with a agressive compound and work to fine you will safe alot of work buffing the sanding scratches then move to finer compounds.
later is offline
Old 06-04-2003 | 03:54 PM
KCHOTBOAT's Avatar
Charter Member #737
Originally posted by JUST ONCE
1000-1500 wet sand
micro cut compound with a buffer, wool pad
polish with buffer with foam pad
hand wax
Pimp it
In that order
That is the order I am doing mine this week sometime. Puder I will let you know how it turns out. My boat spent to much time on the west coast and the top looks real bad.
David Stotz
Detailing, Painting, & Fiberglass
11
05-21-2007 03:39 PM
pol98xc6
5
02-18-2007 04:07 PM
Reckless32
9
09-01-2005 08:55 PM
aTX427
19
05-04-2005 05:24 AM
US1 Fountain
8
03-19-2004 11:20 PM
