"92" Webber carb? 7.4 >
Old 06-02-2003 | 07:27 AM
patrick22309
Default "92" Webber carb? 7.4
My question is, can I pull the top of my webber without removing the carbs to clean the bowls. I just purchased the boat and believe it sat often only having 260hr on a 1992 and a wate/fuel sep. full of water/rust. I am just wondering what made it into the carb....
Old 06-02-2003 | 07:44 AM
sure, you will need to pull the metering rods and springs out first. they are located on the outer edges of the choke horn..
cbix is offline
Old 06-02-2003 | 07:37 PM
MACDAD260's Avatar
Charter Member #818
Webers are easy enough to work on. Just remember to also unscrew the flame arrester hold down bolt when you remove the screws to take the top off. As cbix said you should pull out the metering rods and springs before you take off the top. It is very difficult to put it back together if you don't. To remove the rods all you need to do is loosen the screw on each cover a couple of turns and then the covers will swing out of the way. Once you do it you will see how it works. Good luck.
MACDAD260 is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
ECeptor
11
04-24-2006 02:30 PM
Scott
7
01-02-2003 10:05 AM
mikesufka
12-26-2002 11:23 AM
