Time to decide on which oil to run this year >
View Poll Results: Which oil to use ?
Royal purple 20w-50
6
37.50%
Redline 20w-50
4
25.00%
Valvoline VR1 20w-50
3
18.75%
Valvoline race 20w-50
3
18.75%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Old 06-05-2003 | 03:14 PM
bobby daniels
Thumbs up my thoughts on oils
Really a multi weight oil syn.is the best way to go with modern oils!
Years ago multi weight oil used to break down under load and today multi weight oil (syn ) is really not going to do that but alot of people from the old school still belive this to be a problem ,I and alot of builders I know((( RaceteamsIncluded))) use a multi weight syn. in their motors with turbo's and blowers and have no trouble with the multi weight syntheic.
Its easier on the motor to start and everytime you slow down and loff along and the oil cools down then you jump on it to pass a friend !!
Also you need the right weight for your clearances in your motor
if you use multi weight the oil is right for the temp of the motor ,ect.
It does hold up and is better really ! if you change it often every 20 or so hrs. I like the SYN AMSOIL racing oils if you go longer or have less load a 10w40 marine and diesel AMSOIL is killer
The MAIN THING IS USE SYNTHETIC OIL PERIOD !!!!
My 2 cents worth
Old 06-06-2003 | 05:56 PM
bobby daniels
Default HAVE A GOOD WEEK-END
TTT//GOOD TOPIC
Old 06-06-2003 | 08:38 PM
gofastpilot
Default which oil to use?
I'm using 15-40 HD Wolfshead, Dont believe in real heavy oil takes to much power to pump heavy oil.............gofastpilot
Old 06-06-2003 | 09:02 PM
sgrady's Avatar
Have to agree with Bobby, Amsoil !!!
sgrady is offline
Old 05-03-2004 | 09:18 PM
Default Re: oil
Originally posted by muffman
I have only seen valvoline VR1 Racing oil in SAE 50W not in multi weight
muff, I get Valvoline VR1 Racing 20-50 at NAPA
Kidnova is offline
TeamSaris
Superboat
3
06-12-2007 03:23 PM
Mike Paula
Checkmate
4
12-27-2005 07:24 PM
jb
12-03-2003 01:01 PM
Rick252
01-27-2003 10:05 PM
