-   -   Oliver parabolic rods? (https://www.offshoreonly.com/forums/general-q/52116-oliver-parabolic-rods.html)
dyno 06-11-2003 06:40 AM
are they worth the extra money? say on a 500-600 Hp big block turning less than 6000 rpms?
26scarab 06-11-2003 06:57 AM
In my opinion engine parts are like alcohol, the higher the price the better the quality or so it seems.
although Oliver's might be a little overkill in that combo. I'm sure some Eagle, or Lunati's would be just fine.
If you go with Oliver rods , you might as well go with a custom Windburg crank, and a Dart block with Billet caps , etc. etc.
;) :D
dyno 06-11-2003 08:38 AM
Just looking for bullet proof on a budget! I'm thinking eagle crank and rods but who knows....
Cord 06-11-2003 08:50 AM
I've heard of quality control problems with Eagle. Specifically, the tollerances need to be checked. I also know that Lingefelter used Olivers in just about everything that he built.
Scott72 06-11-2003 08:56 AM
I've also heard that you have to have Eagle cranks checked to insure quality. I'm running Eagle Rods with no problems although the builder did check them etc... Run up to 5500 with them.
dyno 06-11-2003 09:28 AM
what about the Callies Dragon Slayer?or Cat?
rws 06-11-2003 09:34 AM
I have a set of Oliver Billet Rods in My 406 they are 16 years old they are still nice pieces .I sent them back for reconditioning about 10 years ago.I also Have a set of Their Billet Rods for My 572" I have no experience with them as it has yet to run.The cost is more than two times that of an Eagle Rod.I bought a set of 6.385 Eagles with the L-19 bolt upgrade for My Budget 540" and they were $365.00 delivered. The Olivers were like $1200.00 Of course by buying the Eagles were are cutting our own throats by helping to feed the Chinese and the Dirtbags here in the states that are exploiting the cheap labor get richer!
Rob
The Callies Dragon slayers are made in US Forgings They are machined right in Fostoria Ohio. Call Callies 419-435-2711 and Talk to Don or Brook they are good guys.
26scarab 06-11-2003 09:52 AM
Rws,
Your correct about the cheap labor stuff but unfortunalty if I had to go the Callies crank, Oliver or Carrilo rods in my 540 like i would have liked to I wouldn't have been able to afford it.
2 years ago I paid $1300 for an Eagle rotating assy. , Sure I had to have the crank worked on a little (Moldex) to fix the rod journal radii and rebalanced but that was only another $300.
I guess you buy what's within your budget.:)
dyno 06-11-2003 10:00 AM
So if I want to do a budget 496 what would you guys buy? maybe I should start another thread....
Scott72 06-11-2003 10:06 AM
Dyno, I would be interested in this too. I am thinking of building a 496 also next winter, on budget.
