Donzi Z21  What Prop?? >
Old 06-11-2003 | 05:24 PM
Question Donzi Z21 What Prop??
Hi,
My brother is buying a 1990 Donzi Z21 with a 454 (non-magnum) with a bravo drive, and exhause out the side through mufflers. Currently its has a 23 Cleaver and runs like crap.
The marina changed the proip with a Vengance & a 23 Mirage (I was not there and do not know if it was a plus or not) And they got 57 + 59 MPH on GPS Don't know the RPM's either
What props would you suggest we try?
Anybody have any idea's of what kind of speed we should get out of this boat?
Thanks in advance
2Slow is offline
Old 06-11-2003 | 05:47 PM
Get a hold of Darin at [email protected] Email him all the info you have on the boat, he can hook you up. Later 88
88 MACH 1 is offline
Old 06-11-2003 | 08:35 PM
olemissalum's Avatar
go to www.donzi.net and ask there, I am sure there will be someone to help there.
olemissalum is offline
Old 06-11-2003 | 10:46 PM
HOUSTONPROP's Avatar
Default Donzi prop
YOU NEED MORE INFO/ RPMS AND STAY AWAY FROM THE VENGANCE AS THE DIA IS TO SMALL ,THE MIRAGE IS YOUR BETTER CHOICE A 23pitch? BUT NEED MORE INFO,/Darin Thanks 88 Mach 1
HOUSTONPROP is offline
Old 06-12-2003 | 12:23 PM
jdonzi
I have a 88 donzi z-21 468 motor raised x blocked off the side exhaust installed stainless marine through transom exhaust 25 pitch quick silver prop 72mph gps
Old 06-12-2003 | 01:47 PM
If you have a 23" Mirage and you are getting 59 mph gps out of a 330/Bravo thats about it. RPM of the motor should be around 4800. I had an 88 with the same engine combo and that was about it may be low 60 if everthing was perfect.
boomer is offline
t-islands
Prop Talk
5
10-22-2006 05:23 PM
glassdave
Prop Talk
2
07-12-2006 09:26 PM
snake plissken
Prop Talk
12
06-14-2005 06:37 PM
BOATAHOLIC
Prop Talk
7
05-17-2005 07:14 AM
FunHome
04-15-2003 02:00 PM
