high water pressure >
high water pressure
high water pressure
Old 06-16-2003 | 08:05 AM
Thanks Candyman, no crossover, water switches same location, nothing else changed, now the water pump gasket is leaking, also its both engines so I don't think the the gauges are wrong, plus dyno guy said water pressure was above 50 psi. ??????? Guess I won't be making Thunderun.
jeffg is offline
Old 06-16-2003 | 04:52 PM
I think I got this licked. Engine guy installed headers, they removed 2 of the 4 outlets for cooling water from on top of the thermastat housing and plugged it. Gils have fittings for 2 supply hoses, KE has 1, solution is to run 2 into a "y" fitting and then into header, hope this helps someone else out.
jeffg is offline
Old 06-17-2003 | 12:54 AM
candyman35's Avatar
I hope that takes care of the problem. Who did your engines? Are you the 37' out of Worth?
Dan
candyman35 is offline
Old 06-17-2003 | 09:34 PM
Goodwin Competition in Omro WI, I'm downtown.
jeffg is offline
Old 06-18-2003 | 01:46 AM
candyman35's Avatar
Hope you make the run this weekend. It's looking like we may get some nice weather. I think Obren's doing his warm weather dance.
Dan
Ran-Dom 32
34
11-27-2008 10:57 PM
D Harry
10
06-19-2007 08:23 PM
chip12345
19
05-22-2005 05:25 AM
Jrock
11
05-25-2003 01:57 PM
GNJ2
4
12-26-2002 08:00 AM
