Hyd. Helm Unit >
Hyd. Helm Unit
Hyd. Helm Unit
Old 06-23-2003 | 09:13 PM
Elite Marine's Avatar
Default Pump Assist?
Do you still use the pump? Whats the plumbing arrangement?
I assume right/left ports on helm to respective cylinders, but where does the pump and return get plumbed in? If using a reservoir, where does that go in the system?
Elite Marine is offline
Old 06-23-2003 | 10:51 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
There are four ports on a hydraulic helm unit:
P = Pressure from your p.s. pump
R = Right, as in steering to the right
L = Left, as in steering to the left
T = Tank, as in return to the tank
You plumb your powersteering pump pressure to the "P" port
You plumb your right steering to the "R" port
You plumb your left steering to the "L" port
You plumb your low pressure return from the helm to the cooler then to the reservior from the "T" port.
Simple.
Rik is offline
Old 06-23-2003 | 11:41 PM
IRONMAN's Avatar
I do not use a tank, however if you have one then bleeding the system is easier because you have more capacity. it's not really necessary with all systems if you spend time setting them up properly. You need to calculate the volume of the ram or rams, If you have one than you need less volume per helm rotation and two rams require twice the volume per wheel rotation as one to give the same lock to lock rotations. You should have about 3 .25 turns lock to lock when you are all done. use the one with less volume per rotation for a single ram system. Once you go with full steering you will never go back....
IRONMAN is offline
Old 06-24-2003 | 11:16 AM
Rik's Avatar
Rik
You are confused!
A tank refers to a reservoir. Some are remote and some are physically attached to the p.s pump.
They both are the same basic thing and get plumbed accordingly.
If you did not have a reservoir, where would the excess oil volume be?
Rik is offline
Old 06-24-2003 | 11:27 AM
Scott's Avatar
Charter Member #30
Who is confused?
I have a pump/reservoir that is the exact same unit found on a car with a cap and a dipstick attached. That's it nothing else was needed and it works fine.
From Reading Ironman's post he has the same set up!
I have Steps & Bubbles!
Scott is offline
Old 06-24-2003 | 03:46 PM
birdog's Avatar
Thats interesting ! I have never seen a system without a resovoir.
I wonder how they do that ? Any pics ?
Even my buddies new Formula with factory Latham has one.
Not doubting you guys.......just curios.......
birdog is offline
Old 06-24-2003 | 06:41 PM
Allan4
Get a hold of Alfster, he will take care of you. XS Performance Marine is the name of the operation and they are fantastic to work with. I do not have his work number, but his cell number is 513-407-0215. Tell him what you need and that Birdog or Allan said to call. He will set you up at very reasonable prices. Great guys to boot.
Good luck
Old 06-24-2003 | 07:35 PM
Default 2 Lines per cylinder
There are 2 lines per cylinder. So that is where I am confused. I understand the 4 ports on the helm unit, but whats the plumbing on the stern? Are they tied together so that as you pressurize the left outer line it also pressurizes the right inner line??
I guess if someone had a picture it would be much easier to understand.
Here's my current set up:
Old 06-24-2003 | 07:50 PM
Vinny P's Avatar
I hate the winter!!
This is the picture from the installation booklet that I got with my Imco Full Hydraulic steering.. Hope it helps..
Vinny P is offline
Old 06-24-2003 | 09:01 PM
Thats exactly what I thought. Thanks Checkmate!!!
Thanks everyone, hopefully I can get this system on soon!!
littledcsrodshop
Swap Shop
13
12-01-2008 08:33 PM
txriverrat2001
Wanted
3
06-24-2008 12:59 PM
wrenchman
3
06-23-2006 03:33 AM
Elite Marine
Pantera
1
09-04-2003 08:40 AM
twisted mentality
02-20-2003 11:20 AM
