Carb question? >
Carb question?
Carb question?
Old 06-24-2003 | 09:55 PM
Aka8953121
Default Carb question?
What is the difference between a Holly 850 with "race calabration" and a Holly 850 with "marine calibration?"
TIA
Joe
Old 06-25-2003 | 07:47 AM
Official OSO boat whore
Proably has a special throttle shaft bushing to prevent leaks and the vent tubes are pointed back down into the carb throat. There might be some metering changes too, but I'm not sure.
Cord is offline
Old 06-25-2003 | 03:25 PM
blown1500
Marine carbs run richer at part throtle and have the vent tubes that put any flooding fuel into the venturies instead of allowing it to run out onto the engine-fire hazard, you know. If you use a not-marine carb, be sure to check your cruise mixture to be sure you don't melt a motor cruising as well as check full throtle!!
boatfreak
5
07-22-2008 03:02 PM
ak
4
05-17-2008 08:57 AM
WMF
2
05-06-2008 06:36 AM
HyperBaja
01-19-2003 07:49 PM
