Flo-Scan probs >
Flo-Scan probs
Flo-Scan probs
Old 06-24-2003 | 10:18 PM
dhlaw's Avatar
Default Flo-Scan probs
I have twin flo-scans and one of them stopped showing flow rate and gph. The power to the unit is till good though. Is there a way to check the sending unit??? Are they expensive??
dhlaw is offline
Old 06-25-2003 | 04:18 AM
Have bought and done complete installs of the product, albeit not in 3-4 years. Call them or e-mail them..great product, excellent people. Their website is good for the #'s and e-mail adresses of their key people. Joe Dydasco sales (spoke to him via e-mail 4-5 months ago)...Ken in tech. very helpful, knowledgable about every aspect of the product, and will troubleshoot you over the phone (within reason) If you own a system and need parts, Joe will give you a pretty good discount direct. If your going to own the boat for awhile and don't have them...get the installation/troubleshoot guide and the schematic, very complete. The first system I put in from scratch with no previous exposure to the product, has worked flawlessly from day 1 seven years ago. After calibrating the meter head on a couple of tanks of fuel....whizbang!...I'm within 1.5 gallons on a hundred! Have been for years! ( I cal'd it over 1.5, if the totalizer says I've burned 100 gals....I will be putting 98-99 gals in it to fill it again....every time) That's no chit!! Make sure there is a inline fuel filter (I use a napa 3033?) 3/8 metal canister inline just before each sender as a piece of aluminum schrapnel from the tank will jam a sender rotor (no signal) but a jammed rotor will not effect flow to the engine! If I remember correctly the "prefilter" has to be a certian distance min. ahead of the flow sensor for best accuracy. (read: smoothest flow thru the sensor). The "air traps" (I have them in my personal system) are said to further tighten accuracy also! Now may be a good time for a Flo-Scan systen tune up! Good luck, and let us know how you make out. Randy
Rippem is offline
Old 06-25-2003 | 09:42 PM
Primal Instinct's Avatar
I have two of the smaller sender units that the Cigarette factory put on my top gun. I replaced them with the bigger units. Let me know if your interested...
Curtis
Primal Instinct is offline
Old 06-26-2003 | 08:45 AM
mcollinstn's Avatar
The light source for the sender could have gone bad. I think they offer an LED replacement now to substitute for the older bulb style.
mcollinstn is offline
thisistank
04-19-2022 01:23 PM
Griff
Prop Talk
2
05-06-2008 01:57 PM
jeff1000man
02-25-2007 09:53 PM
bck
11
09-29-2005 10:32 AM
velocity260
Velocity
7
11-28-2003 08:07 PM
