Storing Bravos in Gear >
Old 06-26-2003 | 08:36 AM
mcollinstn's Avatar
if you run hydraulic lifters, the valves will close on their own in a couple of weeks (a month, tops), and all of the springs will be in the extended position.
Bumping the motor over is not advised. The crank and rod bearings will not be pressurized and you are accelerating wear for those components. Impeller pump will not like it either.
If you are running solid lifters, then back off the rocker adjusters (you'll need to set the lash on spring startup anyhow)...
mcollinstn is offline
Old 06-26-2003 | 11:02 AM
Wally's Avatar
Were doomed!
Actually...come to think of it now......i dont think this will work anyway (junper cable method).....unless you are going straight to the starter motor i think the neutral saftey switch wont allow the engine to turn over.....or am i thinking too early in the morning?
-Wally
Wally is offline
PhantomChaos
06-01-2011 08:09 PM
MILD THUNDER
Swap Shop
5
09-04-2008 06:27 PM
BraceYourself
Drives and Lower Units
4
06-07-2007 10:51 AM
carrboy
17
04-14-2007 07:31 AM
Tinkerer
03-05-2002 08:50 AM
