Rotating Trailer Tires >
Old 06-30-2003 | 07:10 AM
Luv-N-It's Avatar
Default Rotating Trailer Tires
Just curious...does anyone rotate their tires? I guess the only way to do it would be switching left sides to right sides. I'm not seeing any unusual wear. Did a search and found nothing which made me even more curious
Luv-N-It is offline
Old 06-30-2003 | 10:28 AM
Krumbsnatcher's Avatar
Never even thought of it! Seems like the trailer is the last to get the attention. I will ask around.
Krumbsnatcher is offline
Old 06-30-2003 | 10:57 AM
Eternal Warrior
I've wondered about that myself. I've never noticed any unusual wear either.
Old 07-01-2003 | 09:08 AM
lordofall
The reason you rotate tires on a car is that the fronts and rears perform different functions and have different setups (caster, camber, toe). I can't imagine a trailers front and rear tires having much difference, so I see no reason to rotate them.
Old 07-01-2003 | 08:14 PM
Hudson
Only reason I could think of to rotate the trailer tires is if the brakes cause uneven wear on one of the axles. Trailer tires usually get replaced because they rot out and crack, not because the tread gets worn off.
Old 07-01-2003 | 11:39 PM
If you have a multiple axle trailer and one of the axles is slightly off it can cause some uneven wear on the tires. Also, if the trailer is overloaded, boat and trailer weight exceed axle capacity, could also cause uneven tire wear. These are the only situations I could see that would require tire rotation on a trailer.
h2owarrior is offline
jrocket
42
10-21-2011 04:26 PM
JLAY
8
08-26-2006 02:19 PM
Zero Patience
7
12-08-2005 07:33 PM
Mr Gadgets
09-20-2004 10:50 PM
Maritime_Eng
20
04-19-2004 08:21 AM
