Best Prop for 24 ft. V-Bottom? >
Old 07-11-2003 | 12:42 PM
Scott72
I run a 23 pitch Mirage Plus in my 23' Deep Vee. I went smaller because the my Motor was built to run in the 5200-5400 range. I am running at 5300 right now, 1/2 tank, trimmed, with two people. I tried a 24 pitch Hydromotive and could pull 4900+ rpm but I was blowing out when cruising in rougher water. Didn't like all the stern lift.
Old 07-11-2003 | 10:42 PM
Harper220's Avatar
Patrick, I really don't think I could swing the 25p Mirage up to the correct rpm range. The Mirage 3 blade props are true to thier rated pitch, where as a bravo 24 acts like a 22.5, so I wouldn't be able to turn the 25. Thanks for the offer. I would consider selling the 24 bravo to you if my new Hydromotive works out for the best. I ordered it from Julie at Throttle-up in hopes that it will give me much needed stern lift. I ordered it in a 23p and then will look into having it labbed finished.
Harper220 is offline
Old 07-12-2003 | 07:36 AM
Pat McPherson's Avatar
Harper220, you are probably right.
On my boat the 25 Mirage+ lets my engine max out at 4400-4500.
A stock 26p Bravo I max is 4300-4400. Had my 26p Lab finished and gain about 100rpm which is OK for a light load. I looking for a 24p for the days that I load up the boat.
Anyway, If you do decide to sell, please let me know.
Patrick
Pat McPherson is offline
Old 07-12-2003 | 07:44 AM
HOUSTONPROP's Avatar
Default 23 HYDRO PROP
WHEN YOU ARE READY TO LAB FINISH THE PROP, KEEP US in mind/Darin
HOUSTONPROP is offline
Kool-Aid Man
Cigarette
13
04-19-2008 05:09 PM
2 Trick Rick
Prop Talk
2
11-05-2007 07:09 PM
wrinkleface
Nor-Tech
424
09-22-2006 05:12 PM
bshzba
Active Thunder
2
12-07-2005 06:51 PM
warlocking
Prop Talk
8
04-22-2005 04:53 PM
