Cams for 502 MPI >
Cams for 502 MPI
Cams for 502 MPI
Old 07-09-2003 | 12:00 PM
Droopy
Default Cams for 502 MPI
What cams can be put into the 502 MPI without messing up the electronics and if you need the chip reburned who can do it. Any proven cams in these engine to wake them up? Any help would be great! Later....
Old 07-09-2003 | 12:33 PM
bobby daniels
I've used alot of different cams in those motors and the cam I mentioned in the other thread is hard to beat the 741 crane and in that motor the 114* cam is better ,I have dynoed some cams I've had made and they make 40 to 45 more h.p. and better fuel usage but for all around use those cranes are good and change springs and you need to add screw in studs ,send me the box and we can fix it or to AZ.speed and marine ,
The cam helps alot and if you can't replace the heads get a pocket port job done and a valve job with a serti machine ,that will really help
Old 07-09-2003 | 03:34 PM
Droopy
Bobby.....
What sort of power gain would you typicaly see in the addition of the 741 cam? I also have Gil manifolds and high flow KN filter set up. Looking at the specs on the cam it seems quite large for a 8.75 compression engine but I searched and seen a lot of people running it. Whats your e-mail address?
Old 07-09-2003 | 05:39 PM
bobby daniels
droopey the 731 will accelerate harder but will run on big end ,not bad though ,,I would install cam (741) 4* advanced to 5*
I do like to raise the comp. to 9to1 also if the heads are off
the cam on the dyno is around 75 to 90 but I change other things too,, this is a close estimate though on just the cam .
P M me if you need any thing
bcarpman
18
10-09-2008 06:20 PM
cass236
2
07-21-2008 01:00 PM
brian valery
05-17-2007 04:40 PM
carter38
4
09-17-2005 01:18 PM
Steve_H
11
02-07-2004 05:57 PM
