Through-bolt trim tabs??? >
Old 07-16-2003 | 06:38 AM
mpally's Avatar
Default Through-bolt trim tabs???
The screw holes that bolt the ram on our trim tabs to the transom are stripped out. Should we through-bolt the rams or put some 5200 on the trheads and use the current screws? I do not like trhough-bolting anything that is below the water line. It seems that you are just asking for problems. BTW, the actual bolts that hold the trim tabs in place are through-bolted.
mpally is offline
Old 07-16-2003 | 08:29 AM
formula31's Avatar
I think through bolting is fine as long as its done right. On the larger holes I always use West system epoxy to seal the sides of the hole before use. I would use plenty of 4200 on the bolts inside and out and use a backing plate inside or large fender washers.
formula31 is offline
Old 07-20-2003 | 03:31 PM
crmax's Avatar
mine are through bolted
crmax is offline
Old 07-20-2003 | 07:57 PM
Byron
Anthing that needs to be strong or real is through bolted. If they would have done that the first time you would not have the problem now.
Old 07-20-2003 | 08:15 PM
Audiofn's Avatar
Charter Member #232
Through bolts will not be any more likely to leake water into the transom then a screw so I would bolt them in there.
Jon
Put your best foot forward!
Audiofn is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
007joe
Do It Yourself, Boating on a Budget
40
01-20-2008 02:35 AM
Strip Poker 388
11
03-22-2006 01:51 PM
dallas01
Baja
7
01-05-2003 05:27 PM
